  • Replies 46
I really like what you've done here. Will you need to roughen up the walkway?.... just wondering if it might be slippy in the wet (could get muddy from walkers boots & also slippy from moss growth). Cheers, steve
If you can jack each end up a bit it would be a good idea to slip a sheet of heavy duty polythene under each end as poplar does rot quickly when in contact with the ground and moisture.
I would staple some galvanised fencing mesh across the surface to stop people slipping. We have used plasterers mesh quite successfully in the past as well.
