Why not burn seasoned soft wood in log burners
cessna
  • 7 years later...
Sorry to resurrect an old thread. My neighbours just had a vast leylandii taken down. They didn't keep any of the logs because it "tars up the chimney". Would have kept them in firewood for life!
I'm currently burning leylandii and cherry. Was splitting cedar earlier which I'll mix in with all the other random wood I was given. Lucked out when what I thought was horse chestnut turned out to be London plane - made lovely bangs under the hydraulic blade
They live in ignorance it seems . No chance you could of had it then ?
Edited by Stubby
For what it's worth, I burned some coniferous stuff (about 10 years ago now) and be it not dry enough or something else the tar went up inside the chimney and then got wet which activated the acid in the resin. It rotted through a brand new chimney liner in >2 years. The company replaced it for free and said they haven't seen that happen before so it can't be that common!
I might be misunderstanding or oversimplifying but I thought any wood can form creosote in your chimney if you restrict the airflow too much and your flue temp never gets above 150 Deg C. Keep it nice and hot at 200-250 C and you're not meant to have any problems?
