35 minutes ago, monkeybusiness said:
Fosters? Really?
I have never met you but made many assumptions and thought you were a bit of a dude.
I’m more disappointed in myself than anything else - I’ve massively overestimated some fella on the internet!!!
I’ve let you down.
I’ve let Arbtalk down.
Most of all, I’ve let myself down.
(They were on special and the only lagers in the chiller cabinet!)
  • Haha 3
43 minutes ago, Mark Bolam said:
I’ve let you down.
It gets worse!!! You actually bought them? I was clutching to the hope that a well meaning customer had offered you one and you accepted through politeness...
My perceptions are shattered, I feel cheated.
  • Haha 5
52 minutes ago, bigtreedon said:
???? it was my 40th last week
40?! Oh dear, the beginning of the end!
In all seriousness, listen to your body and look after yourself as best you can - it’s a hard job and you are only here once.
I’ve let you down.
So you put them under your coat and walked out without paying anyway.......
This is the job from yesterday before we finished the Corsican.
Snapped willow limb over a pond resting on a BT line which was about as tight as it could go.
Bit of a head-scratcher as we thought that if we took the tips off the limb would want to drop even more and snap the line.
Ended up putting a block in an adjacent tree, remotely setting a pull line, and using some Transit power to pull the butt up off the line as the snap was severed with a pole saw.
Worked just as planned, for a change!
12 hours ago, Mark Bolam said:
I’ve let you down.
Fosters is just Day lager!
Apparently in Russia anything less than 15% was considered a soft drink unless recently! haha
