Taking down these four today (two left at time of photo). Because it wasn't in anyone's way, we knocked over the right-hand middle tree first, whole, sadly not pictured, then I took apart the leaning one on the right closest to the wires, also sadly not pictured. After a quick cup of tea, the boss took apart the biggest one in the middle whilst I was chipping and directing traffic (small one-way street below the four trees behind a terraced wall, crumbling because of the tree roots, which is why they had to come down), then I took apart the smaller one on the left.
(Edit to add... there's also a home heating oil tank hidden in a little plywood box under my leftern tree, which is why we couldn't knock them over.)
Edited by peds
Just now, Ratman said:
Looks like a man up a tree that pedro
Edited to add words, see above
That is the boss up his tree, I did the two on either end today, and we did a straight fell on the other middle one because it didn't have anything leaning backwards. There was a little back road behind the trees, lots of lemmings, so much opportunity to ice a mother, but I managed to restrain myself.
On 12/02/2019 at 15:19, Rough Hewn said:
Nastiest job I've ever done.
Junkie bridge.
Was that an old railway line?
Edit: ignore that, I looked at the pictures with my glasses on.
Edited by eggsarascal
Last weeks work. 34 conifers down and ground out. Had an emergency job come in on the Monday so I had to put it back a day and spend Saturday grinding the last stumps, wouldn’t have been so bad if they didn’t all have bloody iron bars in the trunks [emoji25]. 12 loads of chip but customers kept the thousand or so logs so that was a bonus. The predator 360 worked bloody hard and did me proud but out of curiosity any of you know the best way to sharpen multi-tip teeth? (I have about 50 dull now), also has anyone used the rock multi-tips? Worth the extra couple of quid?
The first pint went down pretty fast on Saturday evening.
And the emergency a split out Holm Oak for a university I do some work for fun climb and it was just make safe and stack brash didn’t get many pics as we had to knock it out quick. The base was riddled with white rot and the standing steam was like a wobbly tooth.
I sharpen multitips with diamond disc on a 4” grinder. (Wear a dust mask).
Bit fiddly and time consuming but can get a reasonable edge back if not mullered. I now use 2 multitips and two standard rhino teeth on my 360. Cuts better and easier to sharpen imho
Nice one. Thanks mate. I’ve got some diamond disks knocking about at the back of the yard somewhere. I’ll Start the sharpening this week.
Cheers
