Little bit of stump and grind last week- demolition site, all trees felled with a 36t machine with sorting grapple😳
With a 36t machine should of just dug them out.:confused1:
They tried, the wall behind belongs to neighbouring flats and moved when they disturbed the root plates. Everything else on site was dug out and went thru tub grinder, I just ground along the wall line 33 stumps all in
A couple pictures from the last few months
. ImageUploadedByArbtalk1455723907.182292.jpg.b869a333c55782a0d87e5fe8211f4a24.jpg
A small block of these made for a challenging day
Felling spruce against the lean, out of a boggy area for the winch, to be skidded out
Big spruce. With hinge cut off as we are not all perfect!
Amazing weather and a post card setting makes for a good larch felling session
