2 minutes ago, htb said:
Failure obviously due to using a spudported saw.....
🤣 the 200t was just for scale, but yeah it's probably Steve's fault. I'll be sending him an invoice for a new dead eye.
1 minute ago, Mark Bolam said:
Did the groundie stop it dead?
The Americans have a word for that (holding a pice of rigging without running it) they call it ‘snubbing’ which I think works well.
9 minutes ago, Mark Bolam said:
Lovely work.
Pretty pointless imo as well as yours, but very tidy.
Joe, were you using rings or a block?
Using a block mate, don't really see the need for rings most of the time.
It was the last rig before I had to chog down,  so he wouldn't have been able to let it run more than a few feet.
What's the reason unless like in my situation you have no space to let it run?
Why let it run if it’s not too heavy? Hold it firm till it stops swinging then lower it with no drama.
Yeah, we lock stuff off all the time if we need to.
Sounds like there wasn’t much else you could do tbf Joe, as you say must be a CTF thing.
Glad you only bust the inside of your pants.
Snubbing is a phrase used for many types of rope work - particularly that relating to horses and boats - it relates to checking the initial movement by simply taking a turn on the rope round a post or similar (RCS?) but then letting it run in a controlled manner once the dynamic energy has been absorbed (I think!).  Different to making fast, which involves tying off etc.
We use it when a boat comes alongside as it allows the boat's movement to be checked using a single cleat and, once that has been done, any remaining kinetic energy can be used to fine tune the position of the boat by easing the line accordingly.
