... just trying to avoid going as much as normally end up getting something ells that I didn't really need...
So being an Aspen user, can lead to a shiny new thing addiction. It doesn't tell you that on the label!
Back to reasons (and proof) why some people should use Aspen.
This carburettor is from a mower, which, not surprisingly, would not run.
The carb bowl was full of jellified petrol. This is a product which forms in ageing pump petrol and blocks carbs and filters. We see a lot of this.
The ethanol content of pump petrol has an electric charge that attracts other polar molecules. Water is drawn into the fuel. Because water is heavier than petrol, it collects at the bottom of the tank or bowl and turns into a gel. At about 0.5 percent water, this is called phase separation, and then that phase coagulates in cold weather, forming this gel, which once formed does not dissapear.
The remedy is to always ensure that petrol is kept fresh, but this is difficult for occasional users or in equipment which is seldom used.
This is one area where the use of Aspen (or other alkylate fuel) will have significant benefits, as the fuel system will remain perfectly clean, even after several years in storage.
I hope you find this of interest.
Hi Eddie, it was a real pleasure to meet you at the Arb show, I will be firing up my echo hedge trimmer for the 1st time this weekend on Aspen :)
Thank you and great to here someone else is giving Aspen a try!
Let me know how you get on.
All the best.
Eddie
Well Eddie got me to give the Fill Partner is go after I poo pooed the 1 I had a long time ago, after a week it's still working so better than the last 1 strate away.
Best thing is no spillover on filling the blower which has proved a pain with every other filler iv had, it fits the 540 s smaller tank hole fine.
Overall quite pleased with it and will continue using it :thumbup:
sent while pretending to do something important on my mobile.
Also nice to meet you again at the show Eddie!
i tried the sample today while milling with the 660. it definitely does smell funny when mixing with the normal 2 stroke to start with. will probably get a proper can as the 660 takes a whole one of the samples just about!
cheers for all your help!
What's the diff between aspen and the stihl petrol?
If you refer to the STIHL MotoMix: For practical purposes, no difference. Both are alkylate petrol mixed with 2% high quality fully synthetic 2-stroke oil.
