Help with Stihl Models.... What makes a "Pro" saw as opposed to Semi-Pro / Hobby(?) saw
1 minute ago, Bob_z_l said:
Does the 460 have a separate pot?
As my earlier question.
26x 46x all even numbers. so even = Pro?
Yes, you can completely disassemble it and replace whatever you need to.  My crankcase seals were fine so I didn't get any further than replacing the piston.
I don't think the numbers work like that. These are the current Pro stihl chainsaws:
WWW.STIHL.CO.UK
STIHL's Petrol Chainsaws for Forestry Work combine useful technology with minimum weight and are indispensable for many jobs on farms and in the forest.
You'll see it includes some odd numbers.  I simply work backwards from the current model. 462 replaced 461 which replaced 460 etc.
6 minutes ago, AHPP said:
If there’s logic in Stihl model numbers, I can’t tell what it is.
Engine size in cubic inches (with decimal point) eg 044 is 4.4 cubic inches or about 74cc
Nah can't be.
Germans don't know what a cubic inch is :)
I haven't looked too hard but I can't see any logic like the Husky system. Just the bigger the first number the larger category/cc the saw
Also m = Mtronic,  w = heated handles etc
Donner und Blitzen!
  • Haha 3
1 hour ago, Gordon S said:
Nah can't be.
IH engines built in Neuss all designated by cubic inches. D239 / 246 / 268 / yada yada
MS460 has a separate cylinder and is a good saw to work on but it's no lightweight. I fitted a Stihl OEM cylinder and piston to the one I bought as it had the plug stripped and a broken ring land on the piston.
10 hours ago, peatff said:
I notice that the professional saws have a black handle insert round the trigger interlock.as opposed to a white or all black rear handle.
ms-241-cm_540x.jpg?v=1582241661
Not always the case...certainly not in todays range- as you can see:
WWW.STIHL.CO.UK
Perfect for harvesting firewood in the forest ✓ Or check out the MS 251 C-BE model with Quick Chain Tensioning and...
Going simply by numbers, you ask for something between a 261 and a 661. The 400 ( which I know and love already ) is a gnat's under the average. The 462 is two gnat's above. I have no experience of the  462, but the 400 pulls a 20" light bar as if it were 13". I expect the 462 to eclipse that.
Even the 362 is rated to a 20" bar by Stihl, and although I dropped mine to the 14" for the electric one, it has a tad more power than my old 038 which ran 20" without complaint for many years.
I'd say that ideally you want a 462, but bear in mind that it's a kilo heavier than 400/362. Those two are an absolute delight to handle, especially when you compare them to an 038!
