2 hours ago, Mark Bolam said:
That, Michael, was simply not cricket.
Nicely executed square cut imo. A straight drive was the intended shot, but 4 runs on the board anyway.
Edited by Mick Dempsey
9 minutes ago, Whoppa Choppa said:
The clue is in the fifth and sixth words I wrote and evidently applies yo.
You going to tell us why, in the absence of other methods of applying real pulling power, a truck or loader or even a tracked chipper should not be used?
Guessing he's down on truck pulls from watching YouTube fails but not having direct experience. Like everything, there's a right and wrong way to pull a tree with a truck. When it goes wrong, it sometimes goes so badly wrong it ends up on YouTube and adds to the myth.
Not too many tracked chipper/tirfor tree pull fails around, because the people who bother to aquire these devices already kind of know what they're doing, regarding trees, for the most part... But trucks ? Every head-the-ball owns one, and uses it inappropriately.
Nothing wrong with using a truck to assist a fell. Like Kenny Rodgers says though, you gotta know when to hold em (winchman take just enough tension. Feller hold off on cutting the hinge any further) and when to fold em (pull smooth, hard, clean, don't spin wheels).
The hard bit is knowing how far you can go. Things like anchor points (both on tree and truck) make a hell of a difference, along with matching the truck to the size of the tree and the amount of lean.
