E10 fuel and chainsaws?
Rhyanna96
1 hour ago, Rhyanna96 said:
Anyone know if the new fuel will effect the way chainsaws run?
Probably, particularly if saw not used daily/weekly.  We won't be using E10 in any of our machines instead will continue to use E5 super grade type fuel in machines used regularly and ethanol free fuel in machines used infrequently.
Edited by Vedhoggar
1 hour ago, Vedhoggar said:
Ethanol attracts moisture and E10 will presumably do this more that E5, so if fuel left in a machine which is not used for a while it may be difficult to start or even may not start at all.
I see some people are deliberately adding 10% coloured water to the E10 and then syphoning off the 81.8% good fuel off the top, so the fact that it absorbs water which sits at the bottom of the tank until it's agitated only becomes a problem if it corrodes something or a globule fouls up the carb.
Only the fuel tanks breathe, the storage container shouldn't so water shouldn't get in until the machine is fuelled and left with it in unused.
  • Like 6
