Hi guys,
 I potentially have some very small scale forestry work coming up and there will be around 50 tons of timber to come out down a byway over a weak bridge.
 I will be extracting with a small alpine tractor and trailer which will has a maximum mass when loaded of 5 tons.
 Personally I believe the bridge will be fine because it's a short span, the full weight will never be on the bridge and horses etc use it all the time.
 The client is a little concerned about damaging it however because if it collapsed it could block the stream which could then flood a neighbouring property. They have suggested I could put down some kind of support over the bridge, such as the kind used to temporarily cover manholes during roadworks.
 I have done some googling but I can't quite find what I am looking for.
 I am of the opinion that a few scaffold boards doubled up would do the job and be more cost effective.
 Does anyone else have any ideas?
Thanks
Is there room to throw a few sleepers down next to the bridge and make a temporary crossing?
We did this to get a dumper across a stream.
  • Like 7
Seems to hold a Jack Russel ok ! 👍
How deep is the drop? Can you drop a few trunks in to drive over and remove them at the end? If you use big stuff the water should still flow in a small ish stream.
