Yeah we lit the wee stove in the lounge last night as it got quite cold around early evening. I heave never burnt so much as I have this winter & spring.  Usually 15 cube a year, over 20 this last year. Thankfully I had the wood to burn, will really need to start laying in extra each year so there is no risk of running out.
I lit mine this morning. Cheers the room up and helps dries the dogs. We have to have the windows open to lessen the smell from my elderly incontinent father's room 🤢 and it's bloody cold
It's warm enough down south, so although the stoves were used much more consistently and 7-10 days longer then usual I've not had them lit since mid may.  It's damp here though, hope we get a decent spell of dry weather once the schools finish, really feels like the country needs all the sun and fun it can muster after the winter we had!
  • 2 months later...
11 minutes ago, kevinjohnsonmbe said:
That's obscene J!
No heating is even discussed in this house before November 🥶
Not before October here and cannot light it as I've just cleaned it out, swept the chimney and put the stove on its back to free up the air control leers which jam up with ash over time.
Also spent half a day fabrication the first of two hot air manifolds to direct some heat into the adjacent room after passing through a duct under the stairs and a 150W ventilation fan.
I tried it last year and it worked well, albeit the fan is a bit intrusive, so I decide to engineer it a bit better.
