12 minutes ago, Ontario Firewood Resource said:
I admit I didnt make a perfect demonstration, I rushed a video onto youtube in excitement in creating content for my youtube channel, but one should get the idea that its up to the user to make the perfect cut. I started of with slight angle cuts on the logs before the demonstration, I could have made straight cuts on the ends for the perfectionists. The tool does not botch the job, its a ruler, not a cutter. If you look at my video on IBC totes, you will see the thousands of logs that I have cut essentially perfectly to fit in the crates, which makes them stack nicer and are pleasing to the customer. I put in the description that I installed on the wrong side of the bar. it is only $10 CDN, so it is very cheap for a Stihl tool. It is not made to be bolted to every Stihl chainsaw.
I'm afraid someone might be trying to invent the wheel.
There is no point in fitting it wrong to a saw and filming it in a hurry and making it look crap.
Honestly just cut them...who cares whether they are the exact same length or not??
If your that worried you should be using a wood processor.
Just live life and if you can't cut them somewhere the right length by eye...someone please help him...
Nice video that 👍😹
I might jump off my sofa again.
Do you need the boingy tool thingy to get the height Mick ?
