8 minutes ago, aspenarb said:
Most of the kids these days cant get a big felling saw started unless they bring their mum along.
Bob
This hurts because it's true. Sorry.
edit - No wonder though, my mum is pretty hench.
Edited by peds
2 hours ago, Billhook said:
Thanks for all the replies
If you had a 44 inch diameter tree to cut down and had a choice of two chainsaws one with a 48 inch bar and the other with a 24 inch bar, is there a situation where any of you would choose the smaller saw perhaps for more control and ease of use?
At the risk of being a clever dick, both. Big bar for the gob (or possibly only the first cut) and small bar for the rest. I like to letterbox and plunge and am not above plunge-halving gobs now and then.
4 hours ago, drinksloe said:
I also tend to bore off centre too if tree not a real biggy, usually bore nearer the outside so leaving the inside hinge longer/bigger than outside.
I don't follow what you mean. Can you explain or post a sketch please.
i did alot of 2.5x bar length fell when i started out couldnt afford a proper saw, still will go back to a smaller bar just to make sure i still can do it. A good amount of climbers i come across cant fell particularly well
372 with a 24" would be my one of my more commonly used saws
Edited by mtt.tr
6 hours ago, Khriss said:
Always poke center of hinge out - wether it needs it or not - little strand left makes pounding in that wedge much arder. K
Always do this on stems, makes them pop over and off easier
No idea how to do a sketch and get it on here.
But generally in commercial forestry the trees will generally have a lean and heavy branches outside the wood and ur trying to fell them at an angle ideally so all branches land inside the boundary fence.
So u usually have extra tension/pressure on the inside side  off hinge.
So wieght/pressures/stresses never equal across hinge.
If the tree is a monster right on ur limit u obviously need to bore the centre equally, but a lot of trees are only slightly above, but still need bored
So I'd bore to leave as much on inside as I could, so instead of boreing equally both sides from centre, I'd just bore from centre towards the outside/fenceline. With a bit off a diagonal poke towards the inside.
If that makes sense, althou to be fair as I read this I could just put a narrow letter box in and have it equal would do the same.
And if possible line my inside hinge up with a big buttress/toe.
Usually with these trees u need as much strength on inside hinge to stop them breaking off on u and flattening fence
