Firewood business ? Could we make it profitable in the first 2 years
4 hours ago, spuddog0507 said:
after Feb 2021 all logs have to be sub 20% moisture so this is another issue to consider,
Only if selling under 2m3. You can still sell unseasoned logs to the customer after Feb 2021 above 2m3 legally.
14 minutes ago, eggsarascal said:
Who's going to police the sale of logs?
There's enough busybodies out there that's for sure. Advertise on FB or whatever and Im sure they will come creeping outta the woodwork reporting folk.
Ive also noticed that to get the RHI for a new Log Burner you have to buy your logs from a Woodsure supplier. Not sure how they police that but I assume you have to provide reciepts to prove you're buying them to get your cash back. Thats kinda scuppered my plans for that unless there is a way around it? I must have anout 50m3 of logs split ready for the instalation next year and if I cant use them then I'll not bother and just keep burning them in the Stove/s and the Ironheart when I come to install that.
I never saw nufinck guv , honest   . I mean I never even there ..
Trigger Andy, the way around the issue is to do what we do, become a registered self supplier, you need to kit yourself up to be able to process store and dry your timber down to below 20% moisture.
It’s costs a fair bit of money to do, but if you have access to a reliable supply of free timber it’s worth it. My out lay was the bio mass boiler and installation, a new steel watertight open fronted structure to store logs in, a telescopic loadall, two wood processors and 200 ibcs.
It’s been burning for over two years and provides heat and hot water for 3 properties.
Yet know someone who did that they get artic loads or sikta cordwood  delivered regular all for own use
Also they built an "self contained" outbuidling  just to be able claim  some adittional RHI tarriff or something.
Edited by Stere
I've been selling firewood for over 15 years,  all barn dried and always sold 20% or below,
You just need alot of barn space and be 1 year ahead of you self.
Also you need a large, regular reliable source of timber,  which I find is the hardest.
I run a tree surgery business and a small forestry company,  so always had a supply.  If I had to buy all of it in, I wouldn't bother, just to expensive to make a profit.
Running as a business it will probably fail , if you run it as a way of life and spend every minute of your spare time cutting logs and are not worried about hours put in to money back you will survive! Nearly every company I’ve seen set up over the last 5 years has packed up after one or two winters.
We run a similar operation to otter and it makes money but I’m pretty sure if I sat down and worked out the hours and diesel wear and tear on equipment put in you could argue it does not.
You vould always buils your own kiln my mate in Wales used a shipping container not sure how it works we dont talk any more he is totaly hen pecked and me and his old Hag never liked each other
