37 minutes ago, Mark Bolam said:
Those steam engines weighed a ton though, the modern diesels are lighter, so payload is increased.
My mistake, must have been the paraffin we used in the lamps that put us over.
  • Haha 3
Hahaha!
In all fairness I’m pretty sure I’ve seen 4.5t ‘dry’ quoted mate.
You know and I know it’s a myth, add fuel, any additions on the bed, gear, driver etc....
Most of the old school steel body 7.5 ton tippers are good for 3.5 ton payload, I have used my mates little MAN tipper truck to get ballast from the pits and that goes about 20kg short of the 7.5 ton limit with 3.5 ton on it inc driver. No capacity left for tools or passengers. 4-4.5  ton would be a realistic payload with a modern 7.5 tonner with an ali body, fill the cab with blokes and chuck all the tools on and you are probably back down to a 3.5 -4 ton payload.
Bob
12 hours ago, eggsarascal said:
4 ton on a seven n half!? When I was throwing cones 350x1 meter cones was 3.5 ton, throw some night lights on you'd be over. I might be behind the times, but 4 ton on a 7.5T?
Had a go at traffic management as well have you eggs. Stick what your good at now lol
16 hours ago, Martin du Preez said:
Smart set up that, is it roughly the same footprint compared to a 7.5?
Yer its more of less the same, sits a bit higher
Great turning circle so you can get in to tight spots and all that
Got a flap on the side you can open as well to squirt into
I looked at an Isuzu N75, aluminium tipper body and 1.2m high sides - came in at 3600kg kerb weight, 3900kg payload (inc driver).
It would need another row of ally planks and a roof but I reckon you could go a hundred or so KG over and get away with it - 12m3 of chip.
Cab was really uncomfortable though. I ended up buying a eurocargo tipper. Less payload but so much more for your money. Auto, cruise and a comfy cab.
Edited by richy_B
I had a 7.2t Iveco Daily with tool box, regular steel tipping unit with alloy plank sides, tarp roof which had a 3.7t capacity. Use of alloy would have made it close to 4t
  Stuart
Did you buy new richy_b?
any pics?
