What’s the best knot to connect a rope to a winch cable when winching weighty lumps or something that will take a lot of winching ?
Been using a bowline on a bight but had it completely Jam up whilst using a 7.5 ton winch which was on a Mog. I wasn’t the one that was operating the winch and I do wonder whether it was pushed hard (pulling lumps of poplar up a steep bank river bank using a high re direct).
Cheers!
That's time to use chain or wire strips. Rope although possibly strong enough will be damaged at the knots & suffer abrasion as it is skidded up the bankside.
Are you using a rope so you can shorten it many time on multiple pulls. Standard Bowline should work and you will get it undone all i ever use when i need to shorten rope to winch stuff near.
I use the loop of a carters hitch with a twig to keep it in place.
I find a sheep shank quicker, still with a twig. Trouble with knots like this is they considerably reduce the breaking strain of the rope  so many turns round a fixed bollard is safer.
