10 hours ago, Rough Hewn said:
For newbies and pro's alike,
Anyone have any questions about any aspect of chainsaw milling,
Please post them here.
Not necessarily on milling itself and this question is out there to anyone whom might know. Rather than running the Granberg sharpener off a battery does anyone know of a 240v -12v transformer that would fit the bill.
Yes, we use them to power a high level warning beacon on sewage pumping stations. The ones we use are made by a company called Coleman but there are plenty of others about.
How about the switched mode power supply from a desktop computer?
You just gotta look at the currents/pixeies it needs..ie 12 xA then look on the bay and get your needs.. or better still put in your specs in and go-google-it...Pushkin the surchin buttons...
just like i did for you .???  The answers in the pic.. or if you like I will say.. 12v3a but better get a 5a and you get extra pixies when you push harder when your grindin your spinny thing ??
edited;to say car batter-charger ??
Edited by Wedgebanger
Lol yeah I looked at that and some old posts on here that mentioned 10 amps as a requirement, hence asking if anyone had actually bought something that does the job.
4 hours ago, Rough Hewn said:
Get a model train transformer. 240-12v with potentiometer.
They'll be around 3A, what is the granberg motor drawing?
A power supply from a gaming PC will be up to 20A at 12V
Many car battery chargers will only start if they see a battery so you would need a small gel  six cell in the circuit.
Hi, I simply run mine off a cheapo battery charger, does the job ....or off my car.
