2 hours ago, Rough Hewn said:
Truth is...
I went to buy a log burner off a timber guy. He had a big stack of straight oak he was going to ring up to firewood.
No I said!
I'll buy that to mill.
So I put a ton in my transit and off I went.
Came back on Tuesday to do another run (only 3 runs I thought).
He's got 5 ton of yew several more tons of oak, bit of larch and sycamore...
Next thing I know, I've got 18 tons of milling logs delivered to my yard.
Well done Saul that would have been such a waste to go for firewood.
3 hours ago, Rough Hewn said:
Got a small delivery of oak and yew, with a couple of large sycamore.
IMG_2532.jpgIMG_2534.jpgIMG_2536.jpgIMG_2540.jpgIMG_2548.jpgIMG_2554.jpgIMG_2556.jpgIMG_2558.jpgIMG_2560.jpg
Should keep me busy for a while.
You keep your yard very tidy, this is NOT easy.
Camera angles ([emoji6]) and 3 hours of moving logs and trailers to get that space clear.
Lasted 40 minutes.
Got to move all the other crap now to set up the Logosol F2+.
[emoji106][emoji106][emoji106]
18 minutes ago, Stihl123 said:
I sealed the ends when I first got the logs, should I seal again now I've milled em?
Thanks
It won't do any harm sealing again with thinned down pva, the stickers should be no more then 16"-18" apart.
Most of your stacks look ok apart from the one at the front that could do with 4 stickers not 3, apart from that all looking nice and tidy.
OK thanks you ?
Will seal again and put an extra row of stickers in
Thanks
I can only dream of such order and neatness ?
1 hour ago, topchippyles said:
Nice to see that banding being put to good use ?
Thanks for the idea
Found it a bit of a nightmare to put on round a log but get some really good tention on them
