You need to assess yourself. If you don’t want to do it, don’t ! If you do then assess it as you climb, don’t shock load it and climb it like you think it’s going to break.
They stand dead for a long time, often it’s the roots that rot before the standing tree.
This! Probably more likely to just fall over than the stems or branches break.
Depends what stage it’s at, dead elm can go from loosing its leaves last year to standing deadwood totem pole for 15 years in a secluded spot.
I’m doing a fair bit of dead Elm at the moment. Some of the stands that have several trunks coming from ground level have a tendency of coming away from the ground if a hangers attached and needs a pull. I wouldn’t consider climbing one of those. Single trunked bigger trees on better drained soil generally seem ok.
I find the biggest danger from doing a fell from ground level is dead limbs breaking off as the main trunk starts to move.
