  On 04/03/2018 at 20:29, openspaceman said:
Sounds like an ideal case for a self gripping puller based around a two spring loaded quadrants, like two giant opposed STEIN adjustable rope grabs. Drop them over the post and lower till the cams are apart, then lift so they self grip, pull the post. To eject crowd forward and lower simultaneously.
Expand
I dit think you would need the spring pieces or  anything  just a c shape of the thick metal welded to a headstock mount with the inner c  slightly bigger than the posts
Drive up to post so the c shape is nextto post turn wheel so post enters the c crowd back and the post be gripped lift post out ground uncrowd and post will become loose
Like how a formwork pin puller works
https://www.google.co.uk/search?safe=off&client=ms-android-motorola&ei=bFS9WvfbJMqy0gXX-peIAg&q=road+form+k+pin+puller&oq=road+form+k+pin+puller&gs_l=mobile-gws-serp.3...38254.43633..44111...2....131.2052.14j7..........1..mobile-gws-wiz-serp.......0i71j0i8i30j0i13i30j0i7i30j0i30.rkjiuY6OwR4%3D#imgrc=x1nnZEAVMxpSMM:
Edited by dent
Expand
Simpler is better to my mind
A grand for 22 of them at 3 meters by half a meter so can get 31 meters across a lawn.
I can’t sleep at night when people borrow my stuff, so it’s unlikely to be hired out.
Read more
