3 minutes ago, Conor Wright said:
Have been keeping an eye out locally for some comfrey that we could transplant for this exact purpose. Doubt it could smell much worse than the nettle potion!
Pack of comfrey seeds is only couple quid👍
Use with caution though, it's really "spready", invasive. My parents had it all over their old garden. It's not too bad as far as invasive plants go though as it's very good for pollinating insects as well as a good fertiliser.
We used to do similar with rabbit shyte when we were much younger and had them as pets. The grass always grew mad where they "went" and the bucket of slop was like turbo charged nectar to plant life.
you lot have been reading Geoff Hamilton's Organic Gardening from the 80s. it was him that made me into the alcoholic slob i am today. if a bloke that fit and eating so healthily can die of a heart attack at his age you may as well go for it
I think the comfrey makes a better all round fertiliser than the nettles. At the minute I've got both stewing away together in a 200l drum, but the nettles are only really in there instead of going on the compost.
When it's ready, it smells like the inside of a cows arse that's got the runs. If you get it on your hands, the smell lingers for days.
Comfrey is very good for feeding tomatoes
13 hours ago, gary112 said:
You need some sheep muck(daggings) in a hessian bag and drop it in a barrel of water for a week or two and then use it as a liquid fertilizer,its brilliant for brassicas.
good for toms as well
Slugs.
Not so bad now that it's hot and dry again but a couple of weeks ago they were a right menace.
What's everyone's favourite way of protecting against the filthy slimy scumbags?
I hate the idea of Slug Pellets so my preferred option is to use copper rings. I started out years ago by buying various types of Cu tape and mesh and other purpose made products. They were a bit crap really; didn't work that well and didn't last very long. I realised that I could do far better myself starting from standard copper plumbing pipe and some basic metal working.
I cut 22mm pipe to a length of about 12", slit it along its length, bend and beat it out flat to a ribbon and then roll that around the other way to end up with a ring of 4" diameter and about 2.5" high. I put these around individual plants in the ground, or I use them to stand pots on if I'm protecting plants in pots. (This should make a bit more sense with the photos).
I've been using them for a number of years now and really happy with them. They're not 100% effective but getting there. Nothing is against slugs to my knowledge. I'm not sure of the exact chemistry but for some reason but slugs hate copper. I've tested it and watched them visibly recoil from it!
It takes a fair bit of effort and time to initially make the rings but I figure they'll last forever now. Being copper they won't rust away obviously. Also pipe is quite a thick guage they are strong enough to sit really heavy pots on.
If I was a salesman I'd have been on Dragon's Den with the idea before now! Never seen anything as good available to buy.
