What is the shortest logs you have been asked to supply?
I have recently been asked by a customer to cut the logs 6"long and split small!!!!
Have you been asked to supply logs (large kindling in my mind) to the above specs.
  • Replies 22
Yes, horrible stuff to cut with a processor because it always falls in the chamber sideways. Luckily we only sell a couple of loads a year.
We do a sub 8" which is just a bunch of short end logs chucked in a crate and some small diameter branch material that does not need splitting. Probably do 10 cube of this a year strangely quite a bit goes to a lady with a Rayburn as apparently it needs short logs :confused1:
Never been asked for 6" but could cut some from billets if required but would charge a premium.
Same as above,get asked for about 10m3 in all per year for small logs, I charge the same unless I have to recut a bag that's longer which is a ball ache ,somebody always want something you haven't got,:thumbup:
We've only had a few requests over the last few years for logs under our normal 10" and I ask if they can go and measure their fire box. They have all given a size bigger than 10" so we just supply them our normal size
