A bit of a handy 5mm thread reclaimer for plastics on saws etc where space allows.
There are a few flavours of these, I find the continuous external threaded ones the best.
Open up the hole, these inserts are tight at 9mm but other makes may vary. Chamfer with a 13mm drill
Use a drop of super glue and wind in with an allen key.
Edited by aspenarb
  • Like 11
After struggling to replace all the gear fluids (axles, gearbox and transfer box) on my dumper with a 500cc hand syringe, I was fed up. So much pressure needed that whatever gun I’ve ever used always leaks from the seal on the screw cap. Hard work, and no gun ever seems to draw up from a can so you end up unscrewing the cap and pouring the can in, getting oily in the process.
So I bought one of these. It turned up yesterday and made it a pleasure to change the gearbox and diff oils on my tipper. It will both suck and blow (stop sniggering at the back) so you can use it for drawing out old oil if the drain bung is inaccessible.
WWW.EBAY.CO.UK
Pneumatic ATF Oil Dispenser is a specialty kit, designed for efficient undercar transmission fluid...
  • Like 6
  • 9 months later...
I made a few oil dispensers out of old gas cylinders.
  • Like 11
These pneumatic grease guns are worth a mention. Grease works out way cheaper than cartridges and you don't have keep stopping to change the feckers.
  • 3 weeks later...
This is a great tool for the money, 2 ft long sealy ratchet. I bought it for 15 quid at LAMMA  a couple of years ago. It's a bit clunky but it's taken some real pulling without breaking. It's clipped into my discovery with 2 Quickfist clamps, which are also great, to use as the wheel brace but it gets used for all sorts of jobs👌👌
Joking aside, I have similar sized socket bar handy in the van, primarily for nuts and bolts but also in case of need, should any knobber decide to try some road rage.
I keep a 1m long 3/4" drive breaker bar in the van, just a cheap one off ebay. Handy for doing the wheelnuts, especially if it was someone with an air gun who did them up previously!
These are a 'how did I manage without them?' tool.  Long multipoint ring spanners, US Pro, only about 30 quid the set👌👌   I have managed to bend the smallest one, trying to undo a viscous fan on a D3 but we were giving it some real abuse and I have since bought the proper spanner/locking tool kit, which is brilliant 👌👌
There are also a couple of offset ring spanners in the picture, only cheap ones but they are also bloody handy when needed👍👍
