whats the best way to clean drill bits?
se7enthdevil
  • Replies 39
treequip, these are not designed for use in a brace and bit drill as they are straight shafted to fit into a jacobs chuck.
lasurus, i am a bit of a tool junkie and you never know when these sorts of things will come in handy.
spiral, that's a great tip about using the diet variety.
i'll stick a close up of them some time tonight.
one of them has dominion on the shaft but other than that they appear blank.
the construction of each drill is a twisted bit of flat that is then cylindrically ground to give the diameter.
there is no central support shaft.
fair enough then, you'd need some arms to put a 24" drill through a bit of wood though.
i think they are meant to go with a tbar handle of some sort as there is a flat ground into the side of the shaft.
It's possible they were meant to be used with a Beam Drill which has a chuck but also a set screw to keep the bit from rotating. See Here Just Google Beam Drill, loads of stuff on Youtube.
As for the brace with the 3 jaw chuck, I have something similar but it actually has a 2 jaw chuck
Edited by R Mac
