2 minutes ago, Gary Prentice said:
DONT.....:FEED.......THE....TROLL..
Shut your cake hole Prentice, you damn moron...
Now where was I!!!...
Eggsarascal..
I was addressing the none-stop bitching of those tenants who are housed by the local authority, and who think its the duty of said authority to re-house them Without any concept of gratitude to that authority for housing em in the first place..
As to the fire, it spread due in large part to the whether conditions on the day, it was very hot from what I remember.. I dare say on a cold winters day the fire wouldn't of been anything like as severe..
Thus, the lesson to learned is to be extra vigilant for fire hazards when its unusually hot... it don't need a public inquiry for that to be realized..
Eggsarascal..
You'd better let the fire services know that when it's cold and wet, that they need less firefighters on duty then. What a financial saving.
Are you for real?
Eggsarascal..
On a cold winters day the air would be denser containing more o2 so probable take of quicker . The cladding was the fuel , the fridge freezer the ignition source and the O2 was all around . Its all you need .
Edited by Stubby
40 minutes ago, eggsarascal said:
You are indeed correct.
Ya know those times when you know you should keep ones mouth shut but just can't help yourself.......9_9
Of course I do! I'm married.
(I didn't with my first wife, that was the problem9_9)
On a cold winters day the air would be denser containing more o2 so probable take of quicker . The cladding was the fuel .
One of the problems with celotex/kingspan expanded foam insulation is its full of air bubbles.
Once it's burning and hot, you almost can't put it out.
2 houses firebombed in Lewes, last year. Fire brigade couldn't extinguish with water.
Fuel and air in a slab. [emoji107]
I think the Grenfell tower residents do come across as being very entitled...
As for them being involved in the inquiry... Well, let's be honest, what do they have to add?
I think the problem is that when an insulated panel is ignited you can not get water on the fire due to the metal covering.
A lump of coal doesn't have many air bubbles... According to your theory that means coal shouldn't burn....
There are 3 components needed for combustion .  Oxygen , fuel and ignition .  Coal wont burn if you stand there and look at it . Add the other 2 components and as you well know it will .  All 3 components were present at the towers .
