Can you fit the 1/4 bar and chain to the 360tes? Just bought one and slightly underwhelmed
I was slightly underwhelmed also give it a few weeks work. My 200 doesn't come out to play much these days
Had a 360 in and was not happy at high revs - the H screw was a bit lean IMO, richened it right up until it was farting like a granny on beans and then leaned it until it was revving well - made all the difference!
Dan and old mill, thanks very much.:)
John P, as already said the 360 runs really well and you shoudnt need a 1/4 chain, the 2511 doesnt even need one, it runs great on a 3/8 too!
As spud said check the H and L needle settings, you will need a D shaped screwdriver and then give it a good few tank fulls to run in. I have the Standard settings in the workshop and will post them up here tomorrow.
JP,  Yes yew can fit the 1/4 b&c to the 360TES.  Bear in mind though,  those tiny chains are no as robust as a 'chunkier' 3/8ths.   Make sure you have removed the spark screen,  that saw is quite different to the 2511 TES in that it takes quite a few tank fulls for it to loosen up.  The 360 is quite a robust saw and will swerve you well.   Failing that my mate has a mint low mileage stihl 201T fer sale if ya can't gel with the Echo.
shud send my 360 yo u fer tuning,  it has a 'de-cat' exhaust which shud make a difference.  I reckon a muff modded one wood give a MS200T a run fer it's money.  Wonder how they wood react to porting?   Shud send about 7 saws to you really!
I'll put a few more tanks through it, it's not bad bad just lacks a bit of top end pep, love my tiny echo, revs it's bollox off, I'm sure this one will catch up!
On 10/22/2017 at 23:15, Mark_Skyland said:
...As spud said check the H and L needle settings, you will need a D shaped screwdriver and then give it a good few tank fulls to run in. I have the Standard settings in the workshop and will post them up here tomorrow.
 To save you the effort as I've got it open. 360TES
Starting position
Hi    2 3/8
Low 1 7/8
Idle  1 1/8
Obviously worth checking yours has the correct carb for these initial settings, you never know! And I'd echo the comments about them often being set up lean, all 3 of my Echo 2 strokes benefitted from fattening up.
Echo Carb Adjustment Table ~ EU spec. < There's a link in post #1that'll let you open or download the Echo specs and procedure for adjustment, then tweak to your preference. HTH
Starting position
Hi    2 3/8
Low 1 7/8
Idle  1 1/8
:thumbup1:
Does it rev it's ollox off because it's tuned weak ?
  • 3 weeks later...
Interesting thread. I've wondered for a while about getting an Echo and while I wouldn't be in a pickle if a part couldn't be got within a couple of weeks, I'd still be wondering why I'd bought a saw, where spares had an unknown availability .
