Tiny echo!
Maxnaggle
Put my CS2511 TESC thru it's paces this week. When I unboxed and assembled it I noted the Echo branded carving bar was very swanky looking and is .50 gauge. I ran it up and immediately felt/noticed resistance and the bar tip 'blued up' with excess heat so I had to really slacken off the chain to the extent it was hanging off the bottom of the guide bar, this to me renders the cutting gear as 'unsuitable'. The saw was oiling generously so no issues there that I can see, however I did not try adjusting the oiler. I swapped out the echo C&B in favour of the stihl MS 150T C&B which is the smaller .43 gauge as this has a nose sprocket as opposed to the Echo solid nose bar which I suspect was the cause of the overheating. I also cable tied 2 small covers as I had them come adrift on the original 2510 seeing as the 2511 is near as dammit identical to the earlier saw and I don't wanna be losing covers. I also added a loop to the tool clip fir extra peace of mind.
Sent from my SM-A300FU using Arbtalk mobile app
Here ya go Fred, I added this short loop to the hand grip to assist the stock tool attachment ring.
  • 3 weeks later...
  • 3 weeks later...
