Just considering alternative vehicles for deliveries. Running a pickup at present. It guzzles fuel and leaves the logs exposed to the elements which have not been kind this year. All our logs get handballed into the truck so being able to tip in makes no odds. Just wondering about a Connect or Dispatch panel van with a load handler on the floor. Any other alternative solutions considered.
Thanks
  • Replies 48
We have used an LDV Maxus for the last 4 years, works well.
You can get 3 cube bags in it and because it's ULW is only about 1700kg it's not overloaded! Easy enough to drag the loaded bags about by the handles to get nearer to the doors, although it has a side load door as well so that helps.
BTW it will soon be for sale as we are finishing with logs!
Iveco Daily swb L10 is my daily driver ,excellent on fuel and turning circle is amazing plus its a genuine 3.2 ton van so excellent for towing and I can squeeze 3 bulk bags in.
Downside is it will get stuck on A WET LEAF !
Ste
  Ashes_Firewood said:
Something like that no good or do you not want to tow a trailer?
Box trailer is better when its wet, but pulling a trailer behind a 4x4 makes its Tacho time.
10 foot x 5 foot IFW gets 2 x 1 cu m bags in easily, might do 3 900m square ones but I dont use those. Think you would want a 12 footer to get 3 bags and a pump truck on.
A
No been down the trailer rout before. Our lanes and driveways are so narrow around here best to have as small a truck or van as possible. Even the pickup is a bit tight some of the places I go.
I use a panel van and on small jobs I just load the brash, rings etc into the back of it, problem is the condensation, not sure how much of an issue it would be with seasoned logs.
I use a transit panel van and load 3 bulk bags in back with trackor then handball them out with a huge plastic wheelbarrow. The barrow makes light work of it. I have just installed a Penny Hydraulics 500kg swing lift in the back, its lifts bags in/out with ease now. I can also drag the bulk bags about in the van on my own (ply floor). Trailers are a no go round here, drives are too tight, roads too small and too hard to reverse in the rain/dark lol.
Read more
