Wood burner or multi fuel
Stoatally
We've moved to the countryside and have what we were told is a wood burner. I think it might be a multi fuel as it has a riddle plate, bottom air slide and an ash tray which I didn't think you got on wood burners.
Is there anyway to tell for sure. It's also the one thing they didn't leave us a manual for :001_rolleyes:
I'm happy if it is wood as we have enough for at least one winter, but would like to know if we can stick other stuff on, maybe got later on to try and keep it on overnight
  • Replies 25
you might find a data plate on the back of the stove if its fairly new if not get a pic on here im sure someone will be able to id it
I thought the only difference between a multi fuel and a dedicated wood burner was having a grate? Maybe that's the same as a riddle plate?
BTW, although there's no rule against it (providing the wall behind the stove is masonry) the back of the stove looks to be too close to the rear wall. This will tend to stop the air from circulating around the back of the stove.
Once you find out what model of Aarrow stove it is, you'll probably be able to find a copy of the manual online and see what Aarrow recommend for a minimum gap.
