My fault entirely giving the old girl a workout ringing up this old beech laid it on the floor and jumped on digger to move the rings ! Had a brain fart and forgot saw was there and threw a ring clean on top of it. Doubt very much be able to repair it so after a shroud. Any other models fit . Also I suppose what’s the ideal replacement! Don’t use it much so can’t warrant new but need it something with the same cc 80ish ?
  • Sad 1
Nice 461, 76cc but I guess just as much power.
  • 3 months later...
Back in April 2016 I modified our tracked TW flywheel bearings to grease-able and to this day the bearings have not needed to be changed .
Its racked up some hours on those bearings so if anyone ever tells you its possible to over grease a bearing poke them in the eye with a stick.
Have got the chipper in bits atm to sort out the engine and anvil so popped off the shaft extension to see how its getting on .
All good 👌
This is the tow 190 with the same rotor @ 500 hours with shagged bearings, it will be getting the same treatment as above.
Knackered
Bob
Edited by aspenarb
  • Like 8
