When I get back
8 minutes ago, aspenarb said:
The Ranger bought it today, apparently needed to be rammed into a lampost to avoid a cyclist, stuffed the rad in the process. I think the driver has just won the DCM.
Bob
0A05CB73-0E10-4F1B-B0CA-B08E3F7A8F4A_zps
Did you put the story in the ‘things that never happened’ file?
On 12/06/2018 at 17:12, eggsarascal said:
Don't keep us in suspense! Picture of the finished job please.
It actually failed in that a pinhole leak appeared later, but he reground and welded a snotter on it, dry as a bone now.
On 12/06/2018 at 15:59, Mick Dempsey said:
For sure, and fill it with Argon to prevent explosions (see pic)
All done and back to work tomorrow
I thought we'd forgotten something when we welded ours!:sneaky2:
Is hydraulic oil a real high risk?
Well according to my welder it’s the build up of heated gases that make it dangerous.
A little bit of research on t’internet showed he had a point, it wasn’t worth the risk and cost nothing extra as he just put a ‘t’ on his argon tank.
