Unless you are on a some kind of bonus scheme that can be stopped if you break something until it’s paid back he can’t make you pay for it from your main wages.
That’s got employment tribunal written all over it
It would have to be part of the written contract too.
That’s right, screw the man who was good enough to have faith in you and give you a job. Smash his kit up then take him to court over your mistake.
That’s the attitude that has this country in such a state, FFS
Difficult to know where to start with this nonsense. Every sentence is whiny codswallop.
Edited by Mick Dempsey
  • 3 weeks later...
Rather poorly cherrypicker, ended up with engine and gearbox going off to be reconditioned all because of a 16quid spiggat bairing failing [emoji24]
  • Sad 2
19 hours ago, Gray git said:
Rather poorly cherrypicker, ended up with engine and gearbox going off to be reconditioned all because of a 16quid spiggat bairing failing emoji24.png
How did the engine cop it John? :confused1:
Bob
How did the engine cop it John? confused1.gif.5e04913ed83def966344ca86f30de10d.gif
Bob
when the Spiggat bairing in gear box went and chewed up the crank Shaft so engine needs taking apart to fix so decided to have it reconditioned while it's in bits
Is it not just a brass bush or bearing in end of crank its knackered?
  • 3 weeks later...
Not the first weld that has failed on the machine! Forst st8 bracket that holds the hydraulic oil filter on, its seeping oil out and tomorrow we will have the welding guy in to try and sort it out.
It’s wearing a bit thin (my patience)
