An alternative to firelighters?
Robbyrasta
  • Replies 54
Pringles,Doritos and nappys yet to try but I will as the inner pyro must be fed sometimes.....
Nappies with wee in will not burn because of the ammonia, that's how they discovered the coating for roofs in fire risk areas because the only thing to survive bush fires was used disposable nappies.
As the title says- are there any sort of products that are the same sort of size but might burn longer?
Or have people found different makes that burner better than other brands?
Is firelighters gel a contender?
Ps not for lighting a log fire, so wet wood isn't the issue....
HI ROB why fire lighter if you have good kinding orange peel good when dry thanks jon :thumbup:
Trust me they do ,i have the burns marks to prove it when one rolled out of stove on fire and me being foolish caught :blushing:
I have too Admit they are not too wet .
Plastic gets very hot .
Ste
