Looks good Stevie! :thumbup1:
Can you lower the chipper and leave it on the lift at a feedable height and chip into the back, for roadside stuff?
Is it an agri-reg machine still?
i have some hilux parts off of my old import if you want them, they are in a box if you want to pay the postage. The front 4 wheel drive wasnt working and i got it all redone but the bits that werent broken i kept, i can take some pics if you want next week.
Anything you could salvage steve would be a great help. Finances aren't too good ATM but I'll be able to pay the postage. Here's the model details
Toyota details
Model kf-ln167-TRMDS
Engine 3L
Frame ln-167 0017650
Trans/axle g52 AO5A
The g52 is the code I need for the part. It's not a vw badged hilux. It's a real struggle for even breaker parts. I'm after a couple of front seats if anybody has some in reasonable condition lying around?
no all the spraying equipment, pod, boom tank, pump etc will all be coming off and then ill be putting a chest on the back to put my gear in.
Ive used a quarter tank today, been 2 places, done no more than 50 miles!
It needs a new rear diff, with it being an import, there arent any ANYWHERE
whats the difference with the diff? and what about one from a surf they were imported hi luxes with seats, better still buy the full suf you will get a scapper for a couple of hundred quid, really interested what the difference in the diff is.
i would imagine the mounting holes and brackets are similar so if you cant get a diff change the full axle and if the ratio is different put a front one on from the same scrapper, ive had a few hiluxes they are easy to work on and alot of parts interchangable. good luck with it
