chain oil
forestgough
  • Replies 35
Recently went back to using oregon super saw again after a while of using and not being particularly impressed with the oil we've been getting locally (gopart in the white drums).
I have to say I'm a bit disappointed. It always used to be thick and tacky, to the point where on a cold day it almost slid out of the can in sheets. The drum that arrived a couple of weeks ago may as well be cheap engine oil - it's that thin and runny.
Are all chain oils like htis now or does anyone still do a proper gloopy one?
Not to blow my own trumpet. But we do proper old fashioned super tacky oil. Lots of companies are heading towards 120 c/s, ours is still 150 c/s.
Bio oil is £100 for 20 litres in Sweden, £80 for Stihl, £65 cheaper brands. Over winter it was below minus twenty and I have been using rapeseed oil since January, straight out of the supermarket. Cheap as chips and worked well when it's cold, but now it's warmed up a bit, it's just too thin! Just had to buy an expensive barrel! :-(
Anyone know if there can be negatives to using the cheaper rapeseed oil? I found no more wear on bars ect. And had no problems at all that I am aware of! As I said, it is on the thin side, but between minus 25 and plus 15 I found it worked a treat!
  • 4 weeks later...
How much is a 205 ltr barrel of your chain gloop at the moment. We are nearly out.
Bob
Any one tried Scott oil ? Its proper chain lube but designed for motor bike drive chains . I has all the anti fling properties people seem to be wanting . Might be be too stiff I don't know . Expensive buying it in the small bottles sold in bike shops but maybe able to source it elsewhere in bulk for a better price ??
i use gb oils chain oil 30 a drum and it seems good to me ,from local supplier david paton moffat:thumbup:
I've been there once proper good old fashioned repair outfit if it's the one I'm thinking of. No fancy smooth surfaces and shiny image. A proper mans repair shed, I actually got 5 ltrs of husky 2 stroke off him, it was on stock. Only fancy cartons locally in weeny sizes round here. Sorry for derail.
Does anyone use rapeseed oil for chainsaw milling? I feel the bigger bar would need more cling and thicker lube to make the journey round a larger bar?
