Thanks for the reply spud, clean up squish and crown as in remove any carbon deposits? From what I have read.. regardless of how many people have done this mod, I should still double check the squish with the solder through plug hole method?
Yes and yes, what happened to the 064? My guess is the ports free ported after they were widened too much!
I stayed within the 2mm for the piston skirt, I'm guessing I didn't bevel the port edge well enough, ring snagged and completely wrote off the my genuine cylinder, was a sad day and I did throw my toys out of the pram.
And i refuse to ever use a dremel on a cylinder ever again.
Easy mistake to make, the strangest thing is that I have seen pistons fitted back to front with the pin going right up the centre of the exhaust port and apart from strange wear, no other issues or snagging!
Shouldn't be possible!
  • 1 month later...
  • 4 weeks later...
Same thing happens to my wife if my piston is the wrong way abouts.
Sent from my SM-G900F using Arbtalk mobile app
Hi Spud,
I have an MS200t, but it has developed a few niggles and it needs a bit of a tune up and service, maybe even a port if that's possible.
How much is this likely to cost if i post it to you?
Thanks!:001_smile:
  • 1 month later...
He is describing the removal of the KAT which will derestrict the muffler. Some are simple and some are impossible but it is a known improvement.
It is also possible to mess the engine up if the carb isn't readjusted.
Hi spud. I have an old 034 stihl and a spare 550xp that's out of warranty now. What can be done to these saws and what are the costs? I tried searching the thread for more detail but didn't find what I was after.
The 034 currently runs a 18" bar and cuts well but it's sluggish on the uptake and bogs down easily. It'd be nice to run it on a slightly bigger bar for oversize logs and felling the odd bigger tree, even if it meant running skip tooth on a 24" perhaps? It may be getting worn but it's not had a huge amount of use.
The 550 is basically a backup and would be interested to hear what it could be capable of if modded ?
Sent from my iPhone using Tapatalk
