  • Replies 33
Hi
Does look good to stay. But if butt is sound as big J says have bandmill 20 mills away.
Send me a message if I can be of any use.
David
I vote to leave it be, unless serious root issues with the house?
Ha ha ha. You don't get a vote, its not a democracy.
The client has a plan of action in mind the best we can do is offer advice and allow the client to make an informed choice.
Hi there
I have a beautiful, mature, taller than my house, 80 inch circumference walnut tree in my garden.
Sadly it was planters by the previous owner, just 8 meters from the house!
There is plenty of access to the tree to get it down.
We are trying to figure out what to do with it, and would rather not burn such a beautiful tree.
Any suggestions or offers?
The tree is between Cwmbran and Abergavenny, in South Wales
Thanks
Tony
The first thing to establish is, is the timber is any better than firewood. I have seen plenty of walnut stems that are completely goosed either through decay or defects. Its also entirely possible that it has nails or worse in it, garden trees often do and that would reduce its value particularly at a sawmill.
At best the timber is used for gun stocks, at the other end of the scale wood turners like it and take the smaller stuff.
Any value is accrued when the timber is processed, which often means transporting it. Transport can take a bight out of any profit, mobile band mills can mill it on site but you need to get it next to the mill, chainsaw milling is slower and less economic but for a single tree with the potential for inclusions and bad access is probably the best option.
I'd be the first to say have it down usually but it does look a cracking healthy tree from the pic....
If you do take it down could you plant another in it's place?
Just out of interest (as I know it's in your garden), valuable walnut butts are often excavated out of the ground after having their crowns removed as there is a surprising amount of millable timber below the ground level.
As others have suggested, the tree should pay for it's own removal...
Though that's the forester in me talking...
