What Wheelbarrow?
growforest
  • Replies 37
The Haemmerlin Green Standard Metal wheelbarrow
The Haemmerlin Green Standard is a construction grade heavy duty wheelbarrow that is also suitable for domestic and garden tasks. The 32mm diameter frame makes the wheelbarrow well balanced, the 90 litre pan capacity is ideal for most uses and the metal disc 4.00 x 8 wheel gives additional strength.
The French made Haemmerlin Green Standard wheelbarrow is fitted with a pneumatic wheel and is ideal for both hard or soft surfaces.
Green painted metal pan and frame
Rigid 32mm tubular frame
Anti-slip handles
Large pneumatic tyre for use on all terrain types
90 litre load capacity
Metal disc 4.00 x 8 wheels for additional strength
Designed to be stored outdoors
No idea what we pay for them as a shiny new one appears every couple of years.
Liberally soak them in baby oil and read them a bedtime story if you want to.
I just rinse them out and stick them in my polytunnel.
The 120l galvanised ones are more robust and slightly narrower which can make things easier, trouble is also makes them a bit top heavy.
£50 builder center
Fort all the way. Don't know how you lot use those metal barrows, they're so unbalanced.
Most important thing is to spend £15 or so to replace the tyre with a decent one. It makes all the difference, less rolling resistance and down time to punctures is a thing of the past.
