9 hours ago, scbk said:
If you've got a petrol cut off saw (stihl saw) get a terrasaur blade, about £100
Got one. Still can't get a disc cutter more than 8 inches in a hole.
Edited by forestboy1978
This looks promising, ive been looking at a tool that cuts big roots in post holes without blunting, size (12in) is a slight problem but I see they also make a 9in, maybe someone makes a 4in?.
it does look promising - turns out you can get smaller ones, they are called  carbide cluster blades from other manufacturers, maybe this 115mm one on a grinder would be useless, surely you need one on a nine inch grinder if its a thick root?
https://www.ebay.co.uk/itm/Spectrum-KRB115-22-ULTIMATE-Karbite-115mm-Carbide-Cluster-Multi-Purpose-Blade/123645582913?epid=23012079162&hash=item1cc9d9de41:g:fe4AAOSw6Vhbn6F9:rk:6:pf:0
I use one of these. Invaluable for hard clay, sharpen to cut roots (works like an axe) and splits concrete on jobs where it's not worth bringing the hydraulic breaker. I normally dig with a straight shaft grafter/rabbiting spade but near trees and in hard stony ground and dry clay this chissel and the shoveholers will do the job no problem.
I’ve just branched our in to fencing and after first customer wish I hadn’t.
Brief was quickly replace a section of fire damaged fence with “natural “ looking timber and be at least 6ft for privacy.
Bloke is now refusing to pay
