51 minutes ago, AHPP said:
Why a roto tele specifically? The ability to fork? Tight access?
I think they may fit a fly jib with winch, so basically use it in tight access were big crane may struggle to get in
8 hours ago, Mick Dempsey said:
Hi Joe, I was relying on what the client told me.
Anyway I went out this morning and found a slice of re growth from the job that came from the rakings up.
I counted 17 rings, whether that qualifies as “20 or so” I dunno.
The photos don’t really show the tree’s size in all fairness.
Fair play Mick, apologies for calling you out like that.
I've done a fair few 10 year lapsed pollards with similar looking regrowth. Maybe our wetter climate means like grows faster here, or more likely the pics don't do the tree justice
Rotos are much faster than a conventional stick boom, especially when slewing- they are a material handler primarily. There lift chart is often significantly better too.
A late entry from telehandling on Thursday that shows the workflow/layout nicely.
Also an illustration of why I prefer domestic arb to stacking sitka sticks up High Bleakarseburn Fell. Tea being served (on an £80,000 table) with no fear that if I came down for it, I'd have to climb back up up afterwards. The height of civility.
And since I'm here, the cuts. I remember before I did any crane work that it was mystical. I approached a few climbers who appeared to do a good amount of it. Some were helpful. Some acted like unionised stevedores. I vowed to be helpful when my time came.
Hinged up the two thumbs on the back. 600 and 800kg I think. One sling each (not together).
Pick from my first photo of this post, straight up. Pain in the arse flat cut (stubs in the way) and a dog tooth on the back because that's what the crane driver wanted. Two slings. Shackle 1 choked to leg 2, shackle 2 choked to leg 1 (the secret handshake choke).
Slashed off the thumb on the left and rode it down. One sling.
Big column top middle. Secret handshake. 80% of the cut and then wedge so that if the weight sits it down, it opens not pinches the end of the cut.
The 4.something t ball bit from the previous post. Secret handshaked. Nearly cut a < in one side where there wasn't much of a knob to keep the sling down.
Did a stump cut and kept it stood up on wedges while the crane did something else. Came and picked it later.
Edited by AHPP
  • Like 7
