[ QUOTE=Tony Croft aka hamadryad;1152367]500 quid! lmao
dont NEED it, but well now.... I know now what the issue is, I just needed a double cardon shaft, as the lift is the issue, and a VERY common one:thumbdown:
hey ho, all a learning curve, shall know all about drive shafts in another week or two!:biggrin:
Wow £500, I fitted wide angle prop on mine. Did think about a double Cardon shaft, that's As far as it went. Seems ok so far and always grease them up regularly
Sent from my iPhone using Arbtalk mobile app
so how do you upgrade from 3050kg to 3500kg on a 110?
It has a Salisbury rear axle, and is 3499kg revenue weight on the V5.
Do you just get a plate stamped and fit stronger shocks/springs?
Or do you need anything else (rear anti roll bar?) and a vosa test?
Any info would be great :)
Thanks
Charlie.
Hi mate there are some post on about 3500kgs mate on to do it thanks Jon
There is the key
Mine has a lift and stock driveline.
Despite being worked hard it doesn't give any trouble, but then it gets greased regularly.
There is the key
Agree I probably do it too much, maybe every 1000miles I grease the shafts. On the L200 and the Defender
