How do you guys make your gob/face cuts?
I was taught that correct technique is to make the top angled cut first, but I find this technique less accurate. However, if I make my bottom cut first I struggle to get my cuts to meet perfectly and end up with a messy cut. I know its fussy but just want to get better!!
  • Replies 29
You can do the top cut first, then take slices off as you go down, don't go straight for the bottom cut to match, do a cut a bit above first, then you can see a bit better then do the final cut to meet the top cut :)
Try it :)
I always make the bottom cut first, leaves a less messy stump. Have cut the gob upside down before on a tree felling down hill. Just a side note but has anyone done that before?
