Hi mike how much do think it will cost and will have one at the ARB show on demo thanks Jon
You getting a processor then jon don't forget its not just the machine there is 100 k of cord your going to need to feed it 10 grands worth of bag/boxs log deck tele
The fastest is the pinosa followed by a mutitec imo never used either but seen both up close well been operated.
Tajfun are bringing out a 500mm from what I've been told its going to blow the competition out the water
as in splitters /..??
Slowed right down now only 2 cube this week. It's givin us a chance get sorted for next winter, another week and should be done!
How do you make them? They look bloody good!
Hi Ben it only a pellet and wire yes looks good job thanks Jon
I'm going to get another farmi for sub 8 inch it's got to be the quickest on smaller stuff. Just wish it had chain oil not hydro as breathing that in can't be good.
Had a chat with Jim at Riko about this and he reckoned it would be fine to disconnect the oil feed line from the main tank and add your own oil tank which you could fill with rapeseed. Keep meaning to do this to mine just not got around to it.
Just tack the wire on with fencing staples. I use the wire bent back around and cable ties to fix the wire together, surprised how long they last into the 3rd year and haven't had to replace one cable tie yet! Cheap and fast to build.
Hi BEN WORKS OUT TO be £1 per pallet yes thanks Jon
