Bar size for training
Albion435
Its  so you can practice the techniques for bigger tree on smaller trees like boring into the centre of hinge cuts  etc.
Also its the bar length that suits best the 40cc -  50cc saws used on the course & the tree sizes that are felled on the course.
15 hours ago, spuddog0507 said:
I dont think any one will be going round with a tape measure, so just crack on and say nowt, i never known a trainer check bar lengths,,
15” guidebar is the requirement, you will get this information sent to you by the training provider before you start, why would you show up with anything different?
The Stihl light type is 16”, I will allow adjustments for that as it doesn’t come in 15” and the narrow kerf makes it very easy to control for novices.
You show up with an 18” or 20” and you won’t be cutting on my course or being assessed, my jobs on the line so I always check this along with ppe etc.
Simer down a bit, read the original post regarding a 16"bar NO one  mentioned a 18 or 20" bar only you,,
I’m making the point that 15” maximum is the requirement, so turning up with anything bigger and “crack on and say nowt” isn’t going to happen.
Edited by 5thelement
