You need the right tool for the job. That bag lifter looks good.
Gripping something else is just adding more weight and leverage for no reason, and you have no margin for error as it is.
Put your hand in your pocket mate.
(two beers in as requested)
13 minutes ago, Mark Bolam said:
That would work mate, but a fair bit of leverage.
Yep and for heavier loads the boom swiveling and you needing to drop it quickly would become a consideration. What's a bag of rakings though? 50kg? You can always start with an 8' post and cut it down until it's right.
15 minutes ago, GarethM said:
Looks more Arthurian, siege warfare ending.
Still gutted I never went on Robot Wars.
FRANKALVITI.CO.UK
Following discussion with a number of clients, Klou have designed and built a unique brush concept to save your client time and hassle! The new Klou Log Grab/Fork Brush is built...
Take a look  how it is grabbed it will give you an idea, then just fabricate a box section frame with large piece of box section your grab can get hold of.
Grabbing a six foot long bit of whatever that stores piss easily and can be put into action in ten seconds as opposed to ten minutes is enough reason.
1.5 of weak stuff. I'm trying to give up. It's not working.
Edited by AHPP
I just imagine you'd tie the bag off then grab and squeeze the whole thing if it's just rakings, but I just had fizzy water with dinner so obviously not in a thinking mood.
Edited by Dan Maynard
1 hour ago, woody paul said:
FRANKALVITI.CO.UK
That’s exactly what gave me the idea Paul.
Doobin I know you’re right, but I’m after speed with minimum fuck-on.
Alex, 50kg bags I can still hand-ball.
Even up to 100, which is why I got hernias.
I’m taking chocca bags full of wet conny rakings and dust.
Doobin I know you’re right, but I’m after speed with minimum ****************-on.
For the cost of one fencepost and two pegs, just try it. This will spur me on to trying it too. Someone of this parish suggested similar a while ago. Not needed one yet but I have a spare fencepost so why not.
Other thoughts: use more bags and fill them less; grab the bags like Dan said.
