I have to run my stove (Jotul something or other, so presumably a good stove) hard with good dry wood (softwood best) to get the temp of the stove body up to the end of the 'best operation' section.
Dry wood, small logs, air intake wide open etc.
Edited by doobin
Self installed 5kW Morso, my own produced conifer firewood, no stove thermostat, draught on minimum/zero, but easily and quickly boils a kettle, and requires firing restraint to prevent overheating of about 800 sq ft.
It should be that simple, if the wood is dry.
Edited by difflock
Agreed: wood is probably not really dry and chunky.  If you want to prove this get some really dry wood maybe briquettes with kindling and your stove will work fine.
Yes but it's been working fine for weeks with the same batch of logs, but last night I just couldn't  seem to get any heat from it. I had the vents open and their still wasn't  too much heat.
