  • 2 months later...
  On 17/08/2021 at 18:08, eggsarascal said:
S'why exhausts rot out before the rest of a vehicle.
Expand
Exhausts rot because for every gallon of fuel you burn you produce a couple of pints of water. It's the hydro bit in hydrocarbon, it means water 👍 Have you polished inside that stove it looks surprisingly clean ?
  On 29/10/2021 at 14:02, carsmarco252 said:
The inside of my stove is rusty. Rain comes down my flue of the wind blows from the wrong direction and drips onto the firebox. I have a cowl on the chimney pot too.
Expand
Keep your vents open when the stove isn't in use and it should dry.  I keep meaning to squirt a bit of wd40 around the inside of mine when I'm done burning in spring.... But never remember.
Expand
It's because the steam condenses and settles in the exhaust before it gets hot enough to pass out as a gas, wood at 20% moisture produces about 1.5litres for every kilo burned
Expand
1.5kg of water from 1kg of wood?
Edited by htb
Expand
I think he said 1.5 liters of water from 1kg of wood . Seems a lot whatever .
Edited by Stubby
Expand
It depends on the bits of wood to some extent and I made a mistake as I assume fresh wood instead of 20%mc wwb
We can say wood is carbon, hydrogen and oxygen plus the hydrogen and oxygen  in the 20% moisture.
The ratios are approximately 5 carbon, 7 hydrogen and 6 oxygen. that give a molar weight of 5*12+7*1+6*16=163 when that burns it produces 3.5 H20=3.5*(2+16)=63 or 38% of teh dry wood. So with wood at 20%mc wwb thats 0.8kg dry wood and 0.2kg water burning to give 0.51 litres of water. Fresh wood at 50%mc wwb  produces 0.7 litres which is 140% of the weight of dry wood burned.
Expand
That's more believable .
Read more
