Always heard good things about him
Yeah Doug is still going he’s moved shop, and now Abbey Garden Machinery has gone under he’s the only one in tavy, try Dartmoor garden machinery, a guy called Carl, I would take all my kit and chipper to him for all the major works, he’s based in Princetown
  • 1 month later...
Hi All,
I've got a couple of issues with my CS100 - I wonder if any of you can help?
First off, the electric has packed in. I did work but now it just makes a very quiet click and then nothing... the pull cord works okay. Greenmech said they couldn't help as it wasn't 'their' engine!!
Second off, has anyone fitted wider wheels to theirs, ideally with solid tyres? My wheels are well rusty and one of the tyres keeps going flat. Might be easier to just replace them if there's an easy swap, especially if I could 'go large'!!
Thanks...
1 hour ago, bolthole said:
Hi All,
Thanks...
Either a dodgy battery or starter or wiring. Possibly a shot rectifier leading to discharged battery. First test is to measure the battery votage or try a jump pack.
Flat battery, loose earth wires etc most likely course. As we aren't engine dealers, we would steer you towards a Briggs dealer if it is actually an engine based issue.
On 24/04/2020 at 15:32, bolthole said:
Hi All,
Thanks...
Buy a bottle of tyre seal, it will plug the gap and save getting any more punctures
Run the machine, get a tester and Check for a good earth, all wires tight etc. Most likely the regulator, but loose wire is possible
