These are cheap but good, not the most comfortable compared to more expensive offerings but not bad. You can adjust between flood and spot light. Hi and low settings plus a silly annoying strobe. The rechargeable battery lasts ages. Mine is now going into its 2nd winter at work and also gets used in the workshop so hasn’t had a clean easy life. I reckon it was good value for money.
Thanks for all the replies, not sure I'm any further forward as everyone has their own preferences! ?
I should also add it needs to be waterproof - it's for use in Scotland, not the wettest part of Scotland, but still pretty wet for a large proportion of the time.  Predominantly used outside so a good water resistant rating considered essential!
Bought two of these and they great.
Only buy rechargeable now, can’t be done with batteries.
I have that exact one. My only problem is I've lost the charger cable! ???‍♂️
  • Sad 1
WWW.AMAZON.CO.UK
Shop LED Head Torch, OMERIL USB Rechargeable Headlamp with Super... Only buy rechargeable now, can’t be done with batteries.
How long does the battery last ?
It’s a good price isn’t it though
I treated myself to the Fenix 65 dual beam. Waterproof , rechargeable , 3 light level settings for the spot or the flood beam and simple battery indicator . Better than my previous Petzls I have to say.
WWW.GOOGLEADSERVICES.COM
<h3>Description</h3><ul><li>Fenix HM65R is a headlamp with IP68 rated protection that suits for close-in and long-distance illumination. Uses white and neutral white LED's, delivering a max output of 1400 lumens, a max beam distance of 163 meters, and
I would let you plug into mine but I don’t think it’s long enough ?
Get a Coast headtorch. They are expensive, but the best. I have had loads of different makes. HL27 is an excellent all rounder, I have had mine for many years. Have just bought an HL8R for this winter and it is a beast. Extremely bright and the rechargeable battery seems to last 8-9 hours on full beam. I read that LED Lenser are the same quality so I bought one of those last winter, but it was rubbish compared to the Coast.
On 28/10/2020 at 08:42, Lazurus said:
Olight are a good company with quality products but I cannot comment on the head torches but every thing else I have had is top drawer.
Best headtorch I've had, ally body, waterproof and magnetic charger to usb , worth the cost seems bombproof still ~two years in
